bajabaybutcher Initiate Jedi
Posted: Sat Apr 12, 2008 7:16 pm Post subject: top engine hatches |
I notice several of you have grafted in t25 engine hatches into bay's for getting access. I was thinking of a late bay hatch as they are easier to fit. Just wanted to check if there's a reason you used the t25 one like for size? _________________ slide in, life is short. |
72panelvan Jedi Master
Posted: Sat Apr 12, 2008 8:09 pm Post subject: |
I was simply looking for a t25 hatch because they are the most common. The size is an added bonus but I've seen some people on here have narrowed them to make them fit between the rails in the engine bay better. I ended up getting a type 4 hatch so it's a bit of a funny shape but fits in neatly enough and is pretty big. The late bay hatch isn't particularly deep so if your oil filler is right at the front of the rocker cover, you might have some access problems.
Tom |
Posted: Sat Apr 12, 2008 8:22 pm Post subject: |
thanks for the reply Tom  _________________ slide in, life is short. |
Posted: Sun Apr 13, 2008 1:55 am Post subject: |
Urrrm, easier to fit a bay hatch
If your cutting out a hole how much more difficult is it to fit in a bigger hatch?
Fill yer boots. Do it, don't regret it. _________________ The advice you receive on here is worth the paper it's written on.
Posted: Sun Apr 13, 2008 2:18 pm Post subject: |
size matters.
I fitted a cut down t25 one as it was easy to find a donor and you can cut to exactly what you want.
Definatly worth going for the biggest you can fit for a conversion - i did mine back in the days of air cooled and it was useful then as the engine was in and out every week  |
Posted: Sun Apr 13, 2008 2:34 pm Post subject: |
i just figured a bay hatch would be easier to fit as it follows the same florr pattern with the ribs? plus was already meant for a bay.
See this is why I posted, to get views i hadn't thought of  _________________ slide in, life is short. |
Posted: Sun Apr 13, 2008 2:40 pm Post subject: |
early and late bays have different floor rib patterns anyway...just in case yours is an early....the hatches were fitted to later vans with different ribs. T25 ribs were different again if that makes sense!! it doesnt make much difference anyway as i simply closed off each rib end and welded in the part the frame without the rib mouldings. |
Posted: Sun Apr 13, 2008 6:56 pm Post subject: |
ahhh, that i didn't know. about the different rib patterns. I assumed they would be the same as they were bays.doh. n yes mine is an early  _________________ slide in, life is short. |
andewilson Jedi Knight
Posted: Sat Apr 26, 2008 9:52 pm Post subject: |
i decided to cut out the hole to my own size. as big as i could cut it out for the best access. simply cut the hole and made a frame with 25mm angle. when i get a spare minute i'll knock up a hatch door foor it _________________ most bad experiences ive had included cars that werent german. never again |
gazman Padawan
Posted: Mon May 05, 2008 6:02 pm Post subject: |
You've been busy on the Gaz. It's been a while since I looked at your site. Sounds well mean! _________________ The advice you receive on here is worth the paper it's written on.
Posted: Mon May 05, 2008 6:41 pm Post subject: |
my mate who's doing his td splitty at the minute made a hatch in his boot floor from 25mm angle for the frame and the lid is 19mm box with flat plate over the top and a piano hinge but you could use the ribbed section you cut out to blend it in and make it look more factory. here is the picture of the narrowed T25 hatch in my splitty
 _________________ 1964 rat 13 window deluxe 1Z tdi,
