chuggaboom Jedi Master
Posted: Wed Apr 09, 2008 8:27 pm Post subject: |
| iam chucking in a hurst shifter but i want to try and keep it as neeat as possible maybe iam anal about these things |
pugvan Initiate Jedi
Posted: Thu Apr 10, 2008 1:29 am Post subject: |
| Bugsy_malone 666 wrote: | Well my bus is a tad low at the front and going round norfolk I managed to bottom out the suspension and even some of the beam/antiroll bar a fair amount, last thing I want is anything lower than the chassis rails hanging down!
Also having rads between the rails and scoop under it may cause interferance problems. |
hi mate not trying to pis you off but if your beam can hit the floor just think what could hapen if you had a blowout nout should hang lower than your wheel rim its called your scrub line. |
Bugsy_malone 666 Jedi Master
Posted: Thu Apr 10, 2008 6:56 am Post subject: |
| pugvan wrote: | | Bugsy_malone 666 wrote: | Well my bus is a tad low at the front and going round norfolk I managed to bottom out the suspension and even some of the beam/antiroll bar a fair amount, last thing I want is anything lower than the chassis rails hanging down!
No dont worry, I have had a blow out when I caught the tyre on a shitty new road layout at night when other road users wouldnt stay on there side of the road, thats fine no grinding out there (its not that low).
Its more a case of the road in norfolk and being heavily loaded (which i dont do often) but occasionally it happens! I frequently grind the front belly pan thing infront of the axle on speed humps if i drive over them to fast, thats a low point and im just thinking if theres any sort of bars running underneath below the chassis rail there is always the possibility of bending it. _________________ Second Gear All The Way Baby!
Doing Thing Differently. |
