Bugsy_malone 666 Jedi Master
Posted: Fri Apr 04, 2008 11:00 pm Post subject: People with Side shift T25 gearboxes.. |
I was wondering if I could see how you have made you gear change linkages up?
pictures of how the linkages fit would be grand as although I have my own idea for a linkage Its nice to see what other people have that works.
My box is a diesel if it makes any difference? _________________ Second Gear All The Way Baby!
Doing Thing Differently. |
chuggaboom Jedi Master
Posted: Sun Apr 06, 2008 5:35 am Post subject: |
was thinking of doing this but considering i dont have the box yet thet might be difficult to do mock ups
i assume you mean putting a side shift in a bay or split to retain the origanal gear change |
Posted: Sun Apr 06, 2008 11:48 am Post subject: |
well I have a T25 Diesel gearbox, it has a side shifter and its going into a 72 baywindow, making brackets to fit the box is a piece of cake its getting the stock shift mechanism to work when the one on the box is about 4 inches further across and further back than a stock bay one.
hence why I wanted to see some pics of a stock linkage to work out how to make mine work _________________ Second Gear All The Way Baby!
Posted: Sun Apr 06, 2008 9:55 pm Post subject: |
one way is to use the entire t25 linkage
i dont want to do this
i would prefer if it correct inside |
Posted: Sun Apr 06, 2008 10:01 pm Post subject: |
I been trying to see how the shift rod fits on a T25, I'd consider using the hole linkage but i think it goes below the chassis rails and thats not what I want.
from what I have seen T25s all have the sideshift, im sure this cant be the case because the front mount has a cut out for what looks like a front entry linkage.
I am currently working on a linkage to use stock bay linkage with a side shift box. _________________ Second Gear All The Way Baby!
Posted: Sun Apr 06, 2008 10:04 pm Post subject: |
gear linkage under the chasis rails is the other aspect i wanted to avoid
two people on here caddy and ilzlee have both got t25 boxes in bays
but run a the 25 linkage and gear shift
if i find the right gear box i will be trying the same thing |
illzlee Jedi Master
Posted: Mon Apr 07, 2008 11:15 am Post subject: |
as i've said before, if anyone wants to see how mine was done they are free to slide under my van whenever. I'll even be attending some shows after i hand in my dissertation which is due for hadn-in in 27 days, 23 hours and 45 minutes, 30 seconds
29 seconds
28 seconds
27 seconds
god i've lost interest in it...
back to the grind  _________________ '79 Bay running citroen 1.9td and phat tyres! |
Posted: Mon Apr 07, 2008 11:44 am Post subject: |
wouldnt it be easier to jsut post some pictures for us :P  _________________ Second Gear All The Way Baby!
Posted: Mon Apr 07, 2008 11:54 am Post subject: |
Just seen what you posted on kamperchat now exactly what i needed to see to understand how it worked
thanks muchly  _________________ Second Gear All The Way Baby!
illzlee Jedi Master
Posted: Wed Apr 09, 2008 11:03 am Post subject: |
out of interest, why are you and chugga wanting to avoid the exposed linkage underneath?
is there someting i should know?  _________________ '79 Bay running citroen 1.9td and phat tyres! |
Posted: Wed Apr 09, 2008 11:06 am Post subject: |
Well my bus is a tad low at the front and going round norfolk I managed to bottom out the suspension and even some of the beam/antiroll bar a fair amount, last thing I want is anything lower than the chassis rails hanging down!
Also having rads between the rails and scoop under it may cause interferance problems. _________________ Second Gear All The Way Baby!
illzlee Jedi Master
Posted: Wed Apr 09, 2008 4:08 pm Post subject: |
ah i see. my van was low till i had to put phat tyres on it to increase the gearing. i too have a rad between the chassis rails and linkage doesn't foul it... _________________ '79 Bay running citroen 1.9td and phat tyres! |
