Youthy Giblets!!! Jedi Knight
Posted: Mon Jan 21, 2008 11:19 pm Post subject: Power steering unit from vauxhall corsa |
Was it Jp that used one? Just laid my hands on one but never got any wiring with it, are they simple to wire up??? _________________ i really need to start working on my wedgey again!!! |
Posted: Mon Jan 21, 2008 11:38 pm Post subject: |
http://www.vwkd.co.uk/bb/viewtopic.php?t=1309
Ricolas the true pioneer with an actual working system in his Phantom.
Im a copycat but maybe the first in a van??.....alas i havenbt got as far as the controller yet although everythings there awaiting wiring- basicaly without the controller you need to be an electronic genius which im not so im opting to buy a plug in and play variable controller from ebay or RJES when funds allow - anything from £40-£100+ depending on spec. |
ricola Jedi Master
Posted: Tue Jan 22, 2008 10:32 am Post subject: |
show us exactly what you've got to start with... _________________ http://www.ricola.co.uk |
Posted: Tue Jan 22, 2008 10:10 pm Post subject: EPS |
I have a complete unit from corsa B or C not sure which, 54 reg car. I have the whole columb including indicator stalks and the link bar with the two universal joints on the end. It was unplugged from the car so the galv box thats attached to the columb is still in place
How would the unit stand up underneath the van if all electrical connections etc sealed?? I was hoping to mount underneath the van so i can use the origional wheel and not have to worry about playing round under the dash.
On my van (T25) There is a long connection rod with U.J's that joins the bottom of the columb to the steering rack and there is more than enough room to install this setup there
Cheers for the help [/img] _________________ i really need to start working on my wedgey again!!! |
rjes Jedi Guardian
Posted: Sun Feb 24, 2008 12:04 am Post subject: |
A '54 reg is a 'C'. I'm developing a T25 system which will be bolt on, engineered to near OEM spec, which will take the original VW wheel and column switches, in their exact original positions. It'll fit LHD and RHD (RHD slightly easier / neater), and will look almost factory fitted, complete with a new plastic shroud for the lower column, stc. The assistance will be controlled by vehicle speed, as testing in my Syncro (which has 255/55 R18's all round) has shown this, while not essential, will make it very much nicer.
Also see the thread under 'Technical Modifications and Upgrades'. _________________ Regards,
www.rjes.com |
