wellsy Force Sensitive
Posted: Sun May 09, 2010 1:14 pm Post subject: Cast Exhaust Manifolds |
Just seen this post using your exhaust manifolds, didn't realise you did them
Do you have the current price and do you have and complete systems now?
I'll be giving you a call. |
rjes Jedi Guardian
Joined: 30 Jan 2006 Posts: 606 Location: North Staffordshire
Posted: Wed Jun 02, 2010 7:41 pm Post subject: |
The manifolds are out of stock at the moment. As soon as the new batch is cast, the majority of them will be going for fabrication into complete exhaust systems. The complete systems were developed for 2WD and Syncro T25's. The 2wd one also fits late bays. the exhausts have been in production for a long time now. I have sold loads of them. They are designed to be used with the cast sump which I am working on whenever I get a chance. Without the cast sump it is necessary to weld a bracket to a standard Subaru sump, which is not ideal, but does the job.
Be wary of exhausts with only a single small silencer, especially if it's a cheapo stainless Chinese boy racer back box or a bike silencer. I'd guess about 8 customers have tried one of these, and instantly found them unbearably loud. _________________ Regards,
www.rjes.com |
Posted: Thu Jun 03, 2010 10:27 pm Post subject: |
Thanks Rich, I did call and thanks for your time. I've booked in my loom with you (the one with the wrong ECU plugs which I'm trying to source before sending it to you.)
I've been thinking that it needed a couple of boxes to keep the noise down. but its good to hear confirmation I've got a CSP Phython on my type1 engined beetle and its for too loud for what I want the bus for. I though the above 2 into 1 is neat and straight forward to the first box (i.e I can build it) and then put another under the battery tray as its going in a Split. |
paulvandenton Force Sensitive
Joined: 10 Jun 2010 Posts: 17 Location: Bethnal Green
Posted: Thu Jun 10, 2010 11:10 am Post subject: lovely |
| i really want some of these cast exhausts, maybe even a whole system. What do they look like? looked on the rjes website but couldnt find em. |
Bigbadbugga Jedi Knight
Joined: 25 Jan 2009 Posts: 139 Location: nr Liverpool, uk
Posted: Thu Jun 10, 2010 11:43 am Post subject: Re: lovely |
| paulvandenton wrote: | | i really want some of these cast exhausts, maybe even a whole system. What do they look like? looked on the rjes website but couldnt find em. |
There is a picture of them in the pic in the first post of this thread.
They are cast exhaust manifolds, the bits with 'rj' on. _________________ Located near Liverpool.
Building a full custom 1972 Beetle with an EJ25 (n/a sohc),Porsche 944 IRS conversion and Rjes bellhousing. |
Posted: Thu Jun 10, 2010 3:16 pm Post subject: hahhaa |
| sorry for my bad english i was trying to ask what a whole exhaust system looks like, what style how many mufflers etc. I want to get the headers to maybe make my own system but if a theres a whole system available and it looks and works fine ill save myself the trouble!! |
B4Tfink Jedi Knight
Posted: Thu Jun 10, 2010 7:01 pm Post subject: |
looks like this was an easy fix for me, not too loud,
 _________________ 1988 T25 EJ25 n/a.. it just makes more sense that way.. |
Posted: Thu Jun 10, 2010 11:20 pm Post subject: Re: hahhaa |
| paulvandenton wrote: | | sorry for my bad english i was trying to ask what a whole exhaust system looks like, what style how many mufflers etc. I want to get the headers to maybe make my own system but if a theres a whole system available and it looks and works fine ill save myself the trouble!! |
Ah, sorry I misunderstood you a little  _________________ Located near Liverpool.
double post _________________ Located near Liverpool.
Posted: Fri Jun 11, 2010 9:42 am Post subject: mnmmmm |
that is one lovely clean van!!
I see there is like a clamp round the middle of the box, where does it attach to? how is it supported?
looks neat though. how much? |
Joined: 23 May 2006 Posts: 1938 Location: Mudway, Kent
Posted: Fri Jun 11, 2010 1:24 pm Post subject: |
IIRC Rich uses a couple of semi-circle plates mounted onto the engine block. The silencer then clamps onto these.
I can't be more specific, sorry - it was a fleeting glance at one show (we were too busy chatting) _________________ The advice you receive on here is worth the paper it's written on.
B4Tfink Jedi Knight
Posted: Fri Jun 11, 2010 8:12 pm Post subject: Re: mnmmmm |
| paulvandenton wrote: | that is one lovely clean van!!
thankyou
its supported with a bracket welded to the sump a shaped plate bolts to this and bands hook onto it and clamp round the silencer the bracet is also supported by two extended bolts through the cam belt covers from the belt idlers (i chose not to use these to and extended the plate to attatch where the power steering pump and alt bracket a bit ott i know)
more pics you can just see the plate and bracket to the right
