Wiring help please .... (RJES loom strange wires)
buzz1980
PostPosted: Tue May 27, 2014 10:11 pm    Post subject: Wiring help please .... (RJES loom strange wires) Reply with quote
hi all
im hoping someone could help me.
Im helping a friend fit an ej20 into his t25 camper.
He has bought all the kit as a package from ebay very recently with basically everythging so the previous owner had spant alot of money on all pipework,brackets and the most important bit a modidified loom from rjes (all reciepts to prove)
The thing is there are no instructions for the loom ecu and struggling to get a spark.
fuel pump etc is wired but linked a feed to starter motor from the crank wire on the original loom.
The loom is pretty much plug and play and has the extra loom attached that links upto the dash with leds.
does anyone have any idea where these wires connect.
Im struggling with .........
blue and white( seperate wires) wire near to the dash loom which are maybe 10 inch in length.
these are part of the loom that links direct to dash lights/speedo etc
a coiled white wire in the engine bay side
green/red trace wire mounted by loom plugs
none of the wires are labelled or anything so dont know what they may connect too. Sad
any help would be very very gratefully recieved as this is starting to fry my head.
thankyou
buzz
loinfish33
PostPosted: Mon Jun 29, 2015 10:54 am    Post subject: wire diagram Reply with quote
hi did u get a wire diagram for your wiring loom , just I am fitting a ej20 turbo engine to my t2 , if u have a diagram I would buy it from u thanks
1Kingy79
PostPosted: Thu Aug 06, 2015 7:01 pm    Post subject: Reply with quote
Hi. Are you able to do a continuity check back to the ecu connector to find out what pins they go to
If you can tell me ecu pins I can tell you what they will be
I build harnesses for subaru to VW
