1959 Split Screen Kombi Scooby 2.0 Turbo
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Completed Conversions
1959kombi
PostPosted: Wed Jul 01, 2009 8:12 pm    Post subject: 1959 Split Screen Kombi Scooby 2.0 Turbo Reply with quote
Vehicle & model:Split Screen Kombi
Year:1959
Engine details:EJ20T from an early JDM Impreza. Modifications to engine to fit in the Split engine bay :-
Shorter fatter Sump,
Custom manifold to re-locate turbo and improve ground clearance,
Throttle body turned 90deg,
New intake pipe work,
Custom exhaust with bell-mouth from turbo,
MPG: Having too much fun to care
1/4 mile time: Not sure yet, feels faster than my last Bus, that had a 2.4 type 4 and did s in 16.1 sec
0-60:
Top speed: As fast as I dare.
Cooling system details: Belly mount radiator, front cross member hollowed-out and strengthened with 5mm flat to create a intake for the radiator. On the high points on the pipe work I have taped NPT to take blanking plugs so bleeding system is really easy.
Other non conversion mods: Porsche Boxster from brakes, 944 rear trailing arms and brakes
Approx cost of conversion: Dont like to think about this part but probably around 1200+some
[/img]
Post new topic   This topic is locked: you cannot edit posts or make replies.     Forum Index -> Completed Conversions All times are GMT
